Old 04-26-2008, 08:37 PM   #1
mkiiisupra
No response from them, going to probably order the radiator end of the next month. Was going to relocate oil filter and redo the oils lines at same time and get a PWR oil cooler as well and then use the stock oil cooler for the transmission...
At least thats the idea anyone have any other suggestions?
was going to use this as a guide to my relocated oil filter/cooler set up
Tech Tips - Installing a Full Flow, Thermostat Controlled Oil Cooler & Remote Filter - SupraMania
Oh the reason i am going ahead with this now is a have a pin hole sized leak top right section, causes pressure in my cooling system to be off and contstantly pushes coolant into my overflow till it fills up and spits it out.... lol so becuase of it pushing out coolant i have constant air in my system..
Cuases that waterfall noise and in this case isnt a BHG lol
1990 Toyota Supra Turbo A/T
