Old 04-24-2008, 10:22 PM   #33
supramacist
supramacist's Avatar
Alright here's where I sit. I'm adding these pics just so you guys can see where I'm working.
I had the timing set where I wanted it at idle. Now the dizzy is still max'd out. So I went to the idle screw. Minor babystep adjustment and then a re tweak of the dizzy to not have it bottomed out and I was in.
No more codes. The idle is on. Short test drive. Pull codes..., all's well.
1 more test drive. Now I can tell that the idle up for parking lot turns is working. I find myself having to rev the engine a few times to get it to quill back to base line. I make it home and it's reving at 2k rpms again.
And I'm right back to starting over. I'm closing in on it. I just need to grind it out and the 51 will be gone.
But...., why the hell does it keep coming back after a decent miles worth of test drive???? That's my problem.
Edit. I guess the dashpot is the piece in the 2nd pic. Yes, no? Well that thing Has been cleaned off and I don't think it's as springy as it should be. It seems better after I covered everything and applied pb blaster. BUt it's noticabley slow at going in and out.
Name:	Imported Photos 00003.jpg
ID:	1376   Click image for larger version
Name:	Imported Photos 00005.jpg
