Old 04-23-2008, 01:54 AM   #3
mrnickleye
mrnickleye's Avatar
Did the vacuum line come off that goes to the valve on the pump. Its there to up the idle during turns at idle.??
Also, the t-belt did NOT jump teeth. Why would that happen now ?
Disconnect the battery. Let it sit for 15 min then connect it again. Drive the car around the hood for about 10 min, this should allow computer to relearn.
Did you remove the distributor to do the pump clean???
