Old 04-11-2008, 03:54 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Bone_Stock_Supra View Post
As everybody knows, the diff. is held in place with two front bushings and two rear bushings that actually go through the sub-frame. I recently blew the passenger rear bushing out so I have been driving around with the front two and the driver rear holding in the differential. I recently purchased the replacement bushing and the allen-head bolt that holds it in and took it to my local mechanic. He removed the exhaust and even dropped down the swaybar but could not get the bushing pressed into the subframe. Has anybody had this problem? How do you get the bushings into the subframe? Any DIY guides would be very helpful. Thanks!
Have you checked the appropriate section of the TSRM? I'm not sure if it covers rear diff/subframe bushings, but I'd say that's the most likely place you'll find that information. I'd suggest starting in the section that describes removal & reinstallation of the differential.
Life begins at 30psi.
