Old 04-03-2008, 03:26 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Turning the heater on allows the coolant to travel through the heater core, so you DO need to have it on to burp the system. The reason we have to burp our cars is because the heater core just happens to be the highest point in the Supra's cooling system, higher than the radiator cap. This allows all the air trapped in the system to collect in the core. When you correctly bur the car, the angle it sits at allows the radiator cap to become the highest point thus allowing the air (very slowly, so it'll take quite some time) to travel to the cap and exit the system. You will most likely have to burp the system many times to get *most* of the air out.
