Old 03-30-2008, 08:46 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Twin Turbo '95 View Post
ok. then I'll just go single a lot sooner than expected. but 'ill start with a small turbo. maybe a T5/T4 Hybrid. then after all the fun and getting the itch to go faster I'll slap on the T72.
When I do start going for a power car. i thought it would be just smart and order all the parts. and then after i have everything then i can start building it. so then the only time i cant build it is if i forgot about something or if something doesnt fit..
i dont know which of the supra's im going to buy so i dont know what the pistons ect look like and how the car was maintained. so i think that pistons need to be on the list.
Honestly, pistons are a waste of $ until you know for sure you've got an engine that needs them. A well-maintained 2jz-gte with good compression #s should not be opened up. Toyota built these engines right, with extremely precise tolerances (tolerances are several times more precise than a 350 chevy). Race fuel and wider rims need to be on your list - not pistons. Just mho fwiw ymmv...
Life begins at 30psi.
