Thread: which gasket?
Old 03-30-2008, 01:16 AM   #1
suprasath
suprasath is on a distinguished road
thanx for the info about the bore size. im in the same situation as you are about the head gasket. i pulled out my head cost me 400$ to machine and 3angle valve job. my block looks good and the pistons are like gold inside no ridge, so i decided to leave the block and just clean it. but im not sure if the metal head gasket will seal any small scratches.bc when you mahcine it you get back a smooth finish then itll seal. so i ddint want to risk it so im going with copper head gasket.if you have any advice let me knw.
suprasath is offline   Reply With Quote
