Thread: which gasket?
Old 03-27-2008, 05:52 AM   #1
3.0trd
3.0trd is on a distinguished road
hehe, I'm glad I got you thinking! have you already put the motor back together? I'm guessing not, but I could only assume that you would need a wider than stock HG. Since most places only give mm measurements, you may want to get ahold of a digital inside micrometer. Boring the 7M seems to be so common anywhere that sells the gaskets should be able to tell you what you need if you give them the details on what you've had done. Good luck to both of us!
3.0trd is offline   Reply With Quote
