Old 03-26-2008, 08:55 PM   #2
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
You can actually mod the 7MGTE engine with slight diffrences to make it to the 7M-GTEU specs.
The turbo was a CT-26A the A being designated by the A on the housing, basically it just is a bigger housing with a Garrett wheel.
The miggest problem you'll have with the mods is that the engine uses a MAP sensor instead of an AFM.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
