Old 03-18-2008, 01:04 PM   #1
supradaddy0803
supradaddy0803's Avatar
I would say if your levels are good then you probably are fine. The thing with burping the systems you arent going to get out all of the bubbles in the block. These bubbles get trapped and with really good system flow will get worked out. Go ahead and drive it and check your temp and levels every now and then and you should be fine. If you want to really check the coolant pressure then with the engine running and thermostat open grab the top radiator hose and throttle up. You should feel it expand in your hand. This lets you know your water pump is working good.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
