Thread: Supra Problem!!
Old 03-18-2008, 12:55 PM   #3
supradaddy0803
supradaddy0803's Avatar
Yes but the whole system is pressurized. If the grommets are brittle they will leak off the pressure and then you will have none when you try to start again. Hence the missfire. Check those and check your fuel pressure you will probaby be supprised at what you find. I think Supramacist had a post about this a long time ago or posted on someone elses thread. Granted it may not be that but if you replace them now then you will save yourself a problem with a gas leak. Which would you rather have.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
