Old 03-16-2008, 05:47 PM   #1
Knightryder
Knightryder's Avatar
Knightryder is on a distinguished road
Originally Posted by richmond20657 View Post
Can anyone describe what may cause oil in the hose leading to the intake ? Also have small crack in the radiator on top in the plastic is there any fix to this or do i have to buy a new radiator? Also car seems to run fine but when i nail it the boost gauge will only go to 5-6 lbs don't see a\or hear any leaks any suggestions . Thanks
The crack in the rad can be fixed at a rad. shop. they have the tools to do that kinda work, if not I have a rad. I can sell u off my parts car if you want a cheap OE replacement. Also, the boost not being right is the turbo starting to go. Replace or rebuild your turbo and you will notice a huge difference. also it will take care of the leaking in the intake tubes too. You more than likely have a front seal going bad and allowing shaft play which is effecting your boost. That is where i would start by testing for shaft play. easy and free to do with some hand tools....
Knightryder is offline   Reply With Quote
