Old 03-16-2008, 05:44 PM   #2
Knightryder
Knightryder's Avatar
Knightryder is on a distinguished road
you have a turbo going bad. Get it fixed asap before you mess your engine up BAD. You prolly have alot of miles on that turbo thats in there. Take the pipe off that goes from your air filter to the turbo and you will see the turbo impeller. Take and try to move the impeller up and down and side to side. If it moves at all, you have "shaft play" in your turbo. If the impeller is able to move at all you run a risk of really messing up your turbo, or the impeller coming apart and getting shit into your engine. Get it fixed ASAP and stop driving the car. Oil in your intake lines is a turbo seal, and will always lead to turbo failure.
Knightryder is offline   Reply With Quote
