Old 03-15-2008, 03:50 AM   #10
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Originally Posted by CyFi6 View Post
depending on the engine you can start pinging if you remove the egr from the raised combustion chamber temps
Well I believ he is using the 7M-GTE, or are you referring to the age, wear and tear factors. I belive retarding the timing should help with that problem..or is
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
