i thought by '3K in good shape' you meant the shape it is in now, DESPITE the rod knock. i gotcha now though
assuming you do the work yourself, and correctly, youll very easily be able to clean up the entire car and have an almost spotless automobile after the swap, if you decide to go through with it. depending on the outcome and how much luck you have, id say youd be able to get more than 3K
