turbo charging
I wanted to know some info. My friend has a turbo corvair and is parting it out. I just wanted to know if the turbo from the corvair will work with a supra, It is about the same liter and 6 cylinder, but I don't know much about turbo charging. He said he would just give it to me because it is locked up, I found some rebuild kits to rebuild the turbo. So if it will work I have a turbo manifold. What else would I need to make it a success if the turbo will work with it. I am planing to run very low boost like stock, so would I have to change the injectors, and other parts as well.
