Old 02-18-2008, 02:23 PM   #1
Pretaco
Pretaco is on a distinguished road
Its called the heater coolant control valve or something close to that. (water control valve for the heater). You can bypass it, but your heater will always be hot which will hurt your a/c efficiency. Here is the link for the part number: (left hand drive).
Electronics Parts Catalog
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
