Old 02-18-2008, 02:38 AM   #1
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Default ok im back! Check it out...
Hey guys im back. Well heres what happened. I threw a rod bearing and didnt have the money to fix it but its in the machine shop now getting completely redone i mean everything. Costing me only $1,250 im friends with the guys. Here is a list of whats getting done.
New...
Pistons
Rings
Main bearings
Rod bearings
Thrust washers
Expansion plug kit
Oil pump
Gasket set (including the Metal HKS gasket)
Rod bushings
Precision Grind Crankshaft
Clean/prep block
Recondition connecting rods
Rebush connectiong rods
Surface mill Block
Bore hone .020
Resurface head
ARP Head bolts
Then stuff im going to do is...
New...
Water pump
Thermostat
ALL belts and hoses
Stage 1 Clutch kit
electric fan (already installed)
short ram intake (already installed)
other etc things.... lol.
Should be fun.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
