Old 02-13-2008, 06:16 PM   #1
Pretaco
Pretaco is on a distinguished road
Are any of the pistons or cylinders or valves much cleaner than the others?
The coolant leaking into the combustion chamber will usually clean whichever cylinder that is bad, but maybe not if it was a small break and you didn't drive on it very much.
Pics of the bottom of the head, or of the gasket itself might help. Only if you were careful while removing the gasket.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
