Old 02-13-2008, 04:27 PM   #1
Pretaco
Pretaco is on a distinguished road
What were the syptoms before you took the head off?
What does the bottom of the head look like?
From those pics, I would say look at the cylinder walls closely for vertical scratches, and see if the crosshatching pattern is still visable in any of them.
I would also suspect that the head gasket was bad between the #5 & 6 cylinders from the clean spot between those cylinders, but the #6 piston still has carbon build up, so no coolant was getting in there.
But those pics are pretty crappy to be honest.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
