Old 02-10-2008, 09:49 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Alright, I installed the TPS Sensor. It's well within the appropriate resistance values for all of the readings except for the infinite resistance at .7mm gap. it has to go to about .9mm before I read infinite resistance.
The TPS install has solved my rough shifting issues, but my auto trans still slips alot when attempting to accelerate from a dead stop in drive. If I put it down into "L", it locks up no problem.
I also noticed that when I'm driving at WOT, it shifts early for the 2-3 shift and the 3-OD shift. However, it's dead on for the 1-2 shift. Trans fluid is at the proper level, and the rebuilt tranny has only about 50 miles on it. Also, the cable between the trans and throttle linkage has been replaced fairly recently.
Anyone have any ideas?
