Thread: tranny
Old 01-28-2008, 12:42 AM   #1
Pretaco
Pretaco is on a distinguished road
To figure out what type of tranny you have, follow these simple steps:
1. Walk out to your car.
2. Unlock and open the door.
3. Look at the shifter, it should be located in between the two front seats, sticking up out of a bunch of plastic and vinyl trim pieces.
4. Read the lettering on and near the shifter: If it says 1-2-3-4-5-R, on the top of the shifter it is a MANUAL. If it says P-R-N-D-2-1 to the left of the shifter, it is an AUTOMATIC.
5. You can also tell by counting the pedals, checking for a dipstick, or looking at it.
If you have a manual, its the r154, automatic is a540e.
A 1jz bellhousing is required to use the r154 with the 1jz or 2jz engine.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
