Thread: fuel injectors
Old 01-26-2008, 06:16 AM   #1
salomon68
salomon68's Avatar
salomon68 is on a distinguished road
i know i have those white wires and the one brown wire grounded cause that was a problem at first. the engine wouldn't even turn over until i grounded those. i will check on the ecu case and the injectors to see if they are grounded. i'll also check on the timing, that sounds promising. thanks a lot! i'll post back.
salomon68 is offline   Reply With Quote
