Thread: MK4 tranny swap
Old 01-18-2008, 03:27 PM   #1
Pretaco
Pretaco is on a distinguished road
I took the liberty of googling pics of getrag transmissions......
and....
and...
did not find any with removable bellhousings.
So, the 1jz/2jz swap works with the 1jz bellhousing and r154, but the getrag 6 speed swap doesn't work without a 1jz or 2jz.
For those of you that don't like to read:
r154 + 1jz bellhousing + 1jz/2jz =
getrag 6speed + 7mgte =
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
