Old 01-16-2008, 10:56 PM   #15
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Originally Posted by n/a 2 turbo View Post
i did the same thing, i put a turbo on my 88 n/a first of all by the time you can have it running right it costs a bunch of money i still dont have mine running right.. you are going to need bigger injectors 550cc, definetly a hks headgasket and arp bolts, 255 walboro fuel pump, a ecu from a turbo supra the stock ecu cant compinsate trust me, and an afm off a turbo supra along with all the wires, honestly if i knew about all this i would have swaped with a turbo engine i'ts alot cheaper
did you try using an MAF translator? the MAF would more acurately read the incoming air and would even adjust the fuel curve on its own. i would think that if you just slapped a turbo and manifold on, you may encounter fuel cut. so, did you use an MAF translator and a larger MAF?
Irish_Mechanic is offline   Reply With Quote
