Old 01-16-2008, 05:06 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
From what you're saying it just sounds like a loose/worn belt on your p/s pump. I believe the little vacuum lines on the pump help to get the engine to spin a little quicker at an idle when you turn the wheel to help compensate for the extra load on the engine. I don't believe they would cause any sounds or anything. Try tightening the belt and see if that helps. Don't know about the coolant or the A/C not working...
