Thread: Won't Start
Old 01-14-2008, 08:12 PM   #23
mkiiisupra
New spark plugs installed recently, how do i check fuel?
Also new timing belt installed so it has not jumped a tooth
Read about a starter problem with the wiring, hesistant to start or sometimes you just hear the relay click but wont turn the car over. That 10$ part that lets u crank ur engine from the engine bay would that bypass that problem as a means to check if the wiring is bad?
Is there another way to go about this like running power straight from the battery to the starter?
1990 Toyota Supra Turbo A/T
