Old 01-14-2008, 02:45 AM   #1
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Originally Posted by Chambers View Post
Well you can swap the boost gauge out but you wont be able to swap the entire cluster, the restances on the tach are diffrent because of the coil vs. distributer ignition systems.
so if i want to swap out the distributor for a cps sensor.... i'll need a couple of wires and a new tach? maybe i would be better off to just go Coil On.....
Irish_Mechanic is offline   Reply With Quote
