Thread: Won't Start
Old 01-14-2008, 12:46 AM   #1
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Originally Posted by mkiiisupra View Post
White smoke is only during starting, i dont loose any oil. Also i dont not have a first CAT. i imagine the white smoke was due to the carb cleaner residue that was left over on the throttle body/intake penlum after cleaning them (they where completely dry before i put back together)
Like i said she would has never had a problem starting untill i calibrated my TPS. I heard that once u calibrate ur TPS it would throw your base timing out.
I had a chevy for a while that would only smoke at startup, it was white and dissipated after running - it was just a simple valve seal issue. a little oil would seep into the combustion chamber and accumulate while it sat.
as far as the carb cleaner, i was under the assumption you ran it for a while and idled it after putting it back together.
kinda odd tho.... most of the vehicles i've worked on run in an 'open loop' status untill a certain temperature is reached.....generally a set of predetermined perameters....
Irish_Mechanic is offline   Reply With Quote
