Thread: Won't Start
Old 01-14-2008, 12:39 AM   #1
mkiiisupra
White smoke is only during starting, i dont loose any oil. Also i dont not have a first CAT. i imagine the white smoke was due to the carb cleaner residue that was left over on the throttle body/intake penlum after cleaning them (they where completely dry before i put back together)
She has never had a problem starting untill i calibrated my TPS and all the resistances where checked with a ohm meter and are now correct (they where pretty far off). I heard that once u calibrate ur TPS it would throw your base timing out.
I had a mechanic set the timing on my engine once after he put on a new timing belt and he said that was very difficult to set and almost off the scale, i dont think he thought to check the TPS.
1990 Toyota Supra Turbo A/T
