Thread: um help?
Old 01-12-2008, 01:36 AM   #1
west_side_supra
west_side_supra's Avatar
ok now i have another problem, i have ran my fuel pump power onto the ignition wire when i should have put it onto the stock relay, and well i had it running for bout 2-5mins and then it turned off and so did everything else, the only thing that is on during the ignition position is my CEL, that at least is telling me that there is still getting power, but something wrong with my ignition power source, the fuse is fine so what do you think is wrong? i didnt see or smell any smoke so i dont think anything burned up
7MGTE - 500hp never dyno'd
fidenza cam gears
