If all you are wanting is 330 hp then it takes only a little bit from a 1JZ to get that you almost have to reinvent the 7m when you go big or above a certain point ask Aaron from driftmotion. A boost controller intercooler and a fuel rail and you can get over 330 from a factory 1JZ.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
