Thread: 89WhiteTurbo
Old 01-05-2008, 08:18 AM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
well if the hg was changed 5 months ago and theres no probelms with it i would leave it alone but if you want to be in the 300 hp range i would say if the motor is mechanically sound i wouldnt touch cause if memory serves me correct the stock internals can withstand up to 550hp?? correct me if im wrong guys but then i would go with some simple upgrades such as a lightweight racing fly wheel and racing clutch new exhaust sytem to open up the exhaust and let it flow if your turboed go 3" i would say thats what i go with and remove the cats if you can then cold air intake system manual or electronic boost controller right now im running 12-13 psi on the stock ct26 turbo and it boosts good then get a new intercooling system i went 2 and a quarter not to bad of turbo lag but it kick in hardrr now but i would say those are some decent upgrades you could go with to get to the 300 hp range and also get a fcd if you dont want to hit fuel cut im using an hks fuel cut defencer
cyanide-is-a-way-out is offline   Reply With Quote
