Old 12-29-2007, 03:03 AM   #2
dcrusupra
dcrusupra's Avatar
If the A/C was switched on or you pressed on the gas pedal it would set off the code 51. Otherwise, get yourself a feeler gauge and calibrate the throttle position sensor as per the TSRM.
And your heater core is probably shot. It's not the easiest thing to replace so I would make sure that's exactly what it is before going to replace it.
New Rebuild
My CarDomain
