Old 12-25-2007, 09:22 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by rossa1234@hotmail.com View Post
whats the difference? i would like to know if there are advantages in using the "red stuff"?
Thanks..
The green stuff uses silicates to help prevent corrosion. These silicates also tend to drop out of solution to form solids, which can clog the system or damage components such as water pump seals. Toyota Red contains no silicates, while still inhibiting corrosion as good as (or better than) the green stuff.
Life begins at 30psi.
