Old 12-22-2007, 12:37 AM   #1
Pretaco
Pretaco is on a distinguished road
On the power steering reservoir, use one the same size or larger, mount it higher than the pump, and keep the supply line to the pump less than 18" long. At least that's what works for 4x4's, I would think the same rules apply.
The steering wheel mount is typical for Toyota, tapered splines and a 14mm nut. I think most after market steering wheels are universal.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
