Old 12-12-2007, 09:36 AM   #1
jimmys86mkii
jimmys86mkii is on a distinguished road
that is true but you would notice it when the cars at an idle and you wouldnt really get any power id say get a chiltons and jump your system and see what the code reads out to be if it tells you its the air intake temperature signal then you may just need to change the spark plugs. and "IF" you do have water in the plug holes then when you change the plugs spray some ether down in the holes so that it will start right up.
jimmys86mkii is offline   Reply With Quote
