Old 12-05-2007, 03:26 PM   #1
Supra2NR
Supra2NR's Avatar
HEADGASKET
if it still has the stock headgasket have it replaced with a metal one
but in order for you to do this you need to have the block machined
also you get that parthenon, small yellow house, birdcage
to the left of the speedo
that is the low coolant level , jus top off the coolant reservoir and you should be fine
any waterfall sound behind the dash, your coolant needs to be burped
the tailight warning light, if it stays on, jus replace the small; box on the tailight
these are what i can think of right now
and welcome to the forums, you will love your car,
and this forum is more of the newbie friendly type
if you got any other questions,
try using the search feature, and most of the answer should be at the faq section
put your car's info in your signature, and itll be easier for pple to help you when you ask a question
