Originally Posted by IHateHacks
Spudboy, you need to find a fused, switched 12 volt source. I deleted my radio, and used that circuit, as it is fused from the factory.
Thanks Hack. I think I will splice into something like the radio so it will still work. Maybe I'll delete the cig. lighter and use that hot wire so it's deticated. Also will put the fuel cut defencer on the same circuit.
