Thread: Car won't start
Old 11-21-2007, 11:08 PM   #2
supramacist
supramacist's Avatar
If you don't have an air compressor you can use a couple of cans of
compressed air and maybe....., get it running.
Never spray the engine bay without atleast having the car running at minimum.
This is a textbook case as to why.
You also never want to suck water into the air intake.
It will dry out if you leave it sit long enough and work fine.
I can't help with the other.
If you're an n/a you should also check the dist cap for moisture.
