Old 11-21-2007, 10:37 PM   #1
roys88supra
roys88supra is on a distinguished road
you have to have power and ground to make a relay activate. almost every time I have come across your problem it was because the 12vdc battery feed to the relay had no power. take a test light and with the relay removed 1 wire should have 12vdc. (some have 2 wires hot) check that if you feel able and shoot me an IM. I've been a mechanic for several years and specialize in electrical problems.
Good luck
Roy
roys88supra is offline   Reply With Quote
