Old 11-21-2007, 07:06 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Bone_Stock_Supra
No, I did not replace the input shaft bearing and clips when I did the clutch/flywheel job. I did replace the alignment bearing, throwout bearing, and the entire clutch and flywheel with new torque bolts for the flywheel. Is the input shaft bearing known to go bad??
My Mkiv is a TT, so I have no idea about your 5spd. On the 6spd, the input shaft bearing generally doesn't go bad but I do know of one case where it did need to be replaced.
Snap rings are consumables - never reuse them. (see the TSRM for details)
Life begins at 30psi.
