Old 11-19-2007, 07:19 AM   #1
CyFi6
1. You should NOT be driving around with a leaking brake system, thats extremely dangerous, if fluid is getting out theres a good chance air can get in, and when it does youre completely screwed.
2. clean the engine really good all over with some engine cleaner spray and a hose and watch for where you find fresh oil comming from, valve covers are a common place to check.
4. Replace your sealed beam headlight unit thing, the whole glass part comes out and you replace it.
5. The cable is probably stretched, if you can get to where the cable meets the lever and you put a couple zip ties around the cable end just before the end of it, when you pull the lever the ties will contact the latch lever as if the cable werent stretched. Or just replace the cable.
