Thread: Turboing a 7MGE
Old 11-08-2007, 12:04 AM   #1
Chambers
Chambers's Avatar
Unless you get a coil pack, igniter, CPS the 7M-GTE therm housing wont work, the distributer is in the way of the water lines to the turbo.
As for the oil return, on my NA block there is a plate blocking off the return hole for a turbo, but no tapped hole for the oil feed.
"Stuck in the 80's"
