Thread: Turboing a 7MGE
Old 11-06-2007, 07:31 AM   #1
supraman121
Technically you should be able to bolt that on and it should work... but the ecu in the car isnt tuned for it so i dont no what you would do about that, your going to need to find some way to get oil to the turbo and water, iv heard of poeple leaving the water hole unhooked to compensate for no water, iv been told you need a cam positioning sensor but no one will tell me why, and if your going to try to bolt this on i would recommend a boost gauge and maybe a controller, you could always ask a local shop what is need to boost it a tuner shop should know... dont just bolt it on because i said it would work i would ask some shops around what is required.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
