Thread: 7mgte
Old 11-03-2007, 03:40 AM   #1
supraman121
Originally Posted by Supra2NR
If you get a 86.5-87 motor
Be sure to get the same year
Ecu and harness
88 has a bit diffrent color combinations since it was year they were making slight changes to the mk3
88-92 motors came with the similar mounts to the jz series motors
Also diffrent harness and ecu
Any turbo trans should bolt up to any year motor
But I suggest getting an 89 motor, and jus replace the mounts since they use the genuine 7m crank
Instead of the 6m that the pre88's use
U would also need coilpacks
And igniters
And the power steering reservior is diffrent in the turbo motrs
And u should post this on the mk3 section
And yes it would bolt right in with no fitment issues
89-92 is when they changed the engine mounts to acomidate for the 1jz engine, so an 87-88 is very similar the color combination is going to be the same.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
