Thread: 7mgte
Old 11-02-2007, 03:49 PM   #1
Supra2NR
Supra2NR's Avatar
If you get a 86.5-87 motor
Be sure to get the same year
Ecu and harness
88 has a bit diffrent color combinations since it was year they were making slight changes to the mk3
88-92 motors came with the similar mounts to the jz series motors
Also diffrent harness and ecu
Any turbo trans should bolt up to any year motor
But I suggest getting an 89 motor, and jus replace the mounts since they use the genuine 7m crank
Instead of the 6m that the pre88's use
U would also need coilpacks
And igniters
And the power steering reservior is diffrent in the turbo motrs
And u should post this on the mk3 section
And yes it would bolt right in with no fitment issues
