Old 10-31-2007, 10:02 PM   #1
supradaddy0803
supradaddy0803's Avatar
Yes very slowly turn the crank you dont want to put a bunch of unneeded presure on the piston itself. The nice thing is if it is a softer rope then it will have a bit of give and you wont have to worry about damaging things when you do it. On my 86.5 that is what I did to replce the valve guides and it worked. Added time is the fact of haveing to do one then pull the rope out and move to the next one it more tedious than anything.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
