Old 10-31-2007, 05:09 AM   #2
supradaddy0803
supradaddy0803's Avatar
There is a way you can do it I used to do it on older cars with V-8s. It works just takes a little time and you dont have to pull the head. First you pull the plug out and turn the cylinder to BDC and then take a rope and stuff a large portion of it down in the cylinder. Then you turn the cylinder up towards TDC till you feel a bit of restriction. Then as someone holds the crank you comress the spring and remove the spring retainers. Then pull the spring and replace the guide seal. Now putting the spring back on is tricky but with a little skill it can be done then you just move to the next cylinder. Like I have said I have done this many times so I wouldnt have to pull the head and it works great but just takes more time.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
