Old 10-23-2007, 04:38 PM   #1
Supra2NR
Supra2NR's Avatar
Originally Posted by go.stfu
When you drop the tranny mount and the tranny tilts downwards you should be able to slide the end of the driveshaft right out (assuming you took of the center support). Putting it back in meant having to turn the engine over a little to get the grooves to line up.
At least, that's what worked for me. =]
if you ddnt move the car it wouldnt need to get crank to match the teeth
but removing the draftshaft shouldnt take more than 15-20 mins
